Squeaking Noise When Accelerating
14K views 40 replies 8 participants last post by  billybob50
I've been hearing a squeaking noise lately when accelerating. It sounds like leaves rustling. The noise is not reproducible in neutral or downhill, the car has to be accelerating uphill. If the transmission downshifts, the noise disappears.
I thought it might be a wheel bearing, but my tires were rotated and the noise still comes from the front left of the car. It occurs anywhere above 15 miles per hour. I recorded the sound today:
What could it be? I only noticed it after the shop changed the timing belt, tensioner, and water pump a few months ago.
If the shop did the timing belt and accessories, they shouldn't have touched the distributor. To adjust the timing you have to loosen the two distributor bolts and turn the distributor. If I remember, counter-clockwise advances it and clockwise retards it.
When my car was pinging, anytime the revs were below 3k and I floored it, it would ping like crazy. Sounds like somebody crumpling a soda can.
If you can put your trans in 2nd gear probably around 30mph and floor it, see if it does it.
Will it downshift even if you move the shifter to "2nd"? I wouldn't think so, but it might. If you can look at the front bottom of the distributor, where the first bolt is; see if the bolt slot it at the edge. Normal timing is somewhere in the middle, and if it's turned all the way in a direction it's not right.
#13 ·
If it made the noise when the transmission downshifted, could you still hear it physically? Because it could still be making the noise and you just can't hear it because of the engine. Which could be a wheel bearing.
You can check the wheel bearing by jacking the suspected wheel up and putting you hands opposite from eachother diagonally on the wheel. Rock it back and forth and feel for play, there should be very little to none.
#14 ·
I can't say for certain because the change in volume is significant.
I eliminated the wheel bearing as the suspect when the noise persisted after a tire rotation. There is little to no play in any of the wheels.
Maybe the timing was slightly changed when the distributor O-ring was changed, just before the August photo was taken with the chip, and I didn't notice it.
#17 · (Edited)
I was under the impression that wheel bearing noise changes after a tire rotation. I am probably mistaken. Thank you for your help.
I think you're right. Pinging frequency would go up with engine RPMs, while this noise rattles independently. It is probably the front left wheel bearing.
#18 ·
While rotating tyres may change the sounds of bad wheel-bearings, it's not a 100% diagnosis. That's because not all the wheels are balanced the same and not all the tyres are same out-of-round amount. So when you rotate tyres and the sound may or may not change, the wheel-bearing can still be bad, just that it's not being agitated as badly by a wobbling wheel.
Also bad wheel-bearings shows up as shuddering under braking well before you hear noises. Does your front-end shake when you get on the brakes? Does the noise change between coasting and braking?
I suspect that the ignition-timing may be off and causing knocking & pinging. Sounds like shaking popcorn kernels in a coffee tin. Even though the distributor position is the same, if the belt is off by one tooth, that will change your ignition-timing. Verify with a timing-light.
Long-term knocking & pinging can cause irreparable damage. Melted pistons, cracked rings, scored cylinders, burnt headgaskets. Check your ignition-timing with a timing-light. They're dirt cheap and is a good way to double-check a shop's work. That's how I got started with doing all my repairs; about 50% of timing-jobs came back with problems when I had shops do it.
#19 ·
Not at all.
This is embarrassing, I don't understand how to check the timing. The Haynes manual says this:
(1) Connect a tachometer according to manufacturer's specifications (Do I need to buy a tachometer?)
(2) Locate the diagnostic connector and insert a jumper wire between E1 and TE1 (What is a jumper wire?)
(3) Connect the light, find the timing marks on the front cover, let the engine warm up, and the mark on the crankshaft pulley should match up to the 10 degree mark on the timing scale (where are these marks?)
#20 ·
I couldn't really hear anything in the video and this probably isn't the problem you're having, but I had a 1993 3spd Corolla which made a squeaking/Whining/Grinding noise when my differential fluid ran low. I had just done brake work so I assumed it was maybe a dust shield touching or possibly just squeaking breaks or bad wheel bearing.
#21 ·
I haven't checked the differential fluid, but I have not seen any leaks and I changed the fluid a year and a half ago.
I bought a timing light on the way home from work today, and I discovered that the notch shows up here when the engine is fully warmed up and the inductive connector is attached to the left-most spark plug wire looking from the front.
I did not connect any jumper wires. If I need one, where can I get one?
#24 ·
Timing belts stretch over time so if the ignition timing was set when the old belt was installed putting on a new belt will change the ignition timing. Just set it to factory spec and see what happens.
Does the engine run decent otherwise? Good power doesn't feel gutless?
Reactions: Pete Suhman
