1995 T100
3.4l MANUAL TRANSMISSION
Hot restart problem.
Truck starts great in the morning and anytime that you let it sit for over 2hours.
Cranks fine. No error codes, Read with scan tool Engine Coolant Temperature, Intake air temperature, vehicle speed, engine rpm ( all fine).
If I turn it off and try restarting it immediately it starts and runs fine.
The problem is when you drive somewhere and turn the vehicle off for 10 to 15 minutes then it will crank but it won't fire. The only way to start it then is to spray in some starting fluid and then it starts right up and runs great.
I have already changed the fuel filter, and spark plugs, battery is fine and holding a charge.
Any ideas how to solve this hot start dilema. Thanks.
