So I picked it up, and it seems fine! I'm going to miss the RAM's 24MPG, and my truck seems TINY, but I'm glad to have it back.
[EDIT] So I get the truck home and check the spare tire. I prefer to have the spare tire facing down so that I can inflate and check the tire pressure without dropping the tire. I noticed that the spare was stored in the opposite direction, so I went to change it. I noticed that the spare tire lock, which was included with the truck when I purchased the vehicle ($64) was not replaced. This is not an issue for me, as I had intended to remove it, but it may be an issue for some people.
More concerning is the fact that EVERY wiring harness clip on the right side and rear of the truck was either cut off or broken. By my count that was 14 clips, and the wiring harness was left dangling, or supported only where it went through an opening in the frame. I install and repair marine electrical systems, so I used my supply of zip-ties to remedy the problem. If this harness remained unsupported the truck would likely develop electrical problems over time.
Let this be a lesson for you guys that have this done. Surprise your service manager and crawl under the truck and check the wiring harness on both sides.
