Tail lights not working
1 reading
49K views 20 replies 13 participants last post by  Lynn Badham1967
I was wondering if anyone has come across a wiring diagram of the tail lights. Also need the location of the relay so I can check. My brake lights and turn signals work. Just no parking light when headlights are on
That's the only location for the taillight fuse, inside the cabin fuse box. The fuse box under the hood has the headlight fuses and turn signals and such. Should be a 15a fuse for the taillight. What exactly isn't turning on? It doesn't light up when you press on the brake? or it doesn't turn on when it's dark outside ? Also, what trim do you have?
#9 ·
hmmm.. I found a video on the SE recorded at night and the exterior lights that turn on.. the tail lights are on in the video but for you there are no lights coming from the tail light. The headlight switch is on the third position from the bottom, right?.. the light bulb for the tail lights are the same for the stop light so its not the bulb. Best to take it in and let them figure it out.
