Anyone have good knowledge of the electro-magnetic coupler in the rear that applies power to the rear wheels? I generally understand how these types of couplers work, just not certain how Toyota has implemented it.
Setting aside how the ECU decides to apply power, I'm curious how it the coupler actually works. Doesn't seem that there is a lot of info specific on the HL, but I have found a little info on Rav4 sites and assume they are the same units. Some of my questions:
Does the prop shaft (driveshaft, whatever you want to call it) to the rear constantly spin regardless of whether the coupler is engaged?
Is it really just the clamping force of the coupler that "picks" up 50% of the power? I.e., is thereotically possible for greater than 50% of the power to go to the rear if the the clamping force was greater? Without a lockable center differential, it's not clear to me how that "50%" gets to the rear.
Is the coupler fluid filled? Is this a future maintenance issue?
Will the coupler slip/give if the rear wheels were hung up (ignore how you might do this, just trying to add to my understanding)?
I have other questions, but this is a start.
