Hello all,
Just bought a 96 V6 Camry w/ 127k on it about a month ago. When I was looking the car over, I noticed a dealer sticker stating that the Timing Belt and all drive belts were changed at precisely 100k. However, nothing was noted about the water pump (???).
Last Friday, I noted some noise, and upon inspection noticed a small amount of antifreeze leaking from my water pump. The noise was obviously the bearing going out. I got ahold of my mechanic, and set up an appt. early this week to get it fixed.
About 6 hours after leaving my mechanic, I pulled out of work, and the car simply died right in the middle of the road. No noise, etc. It sat at work for the weekend, until I had my mechanic tow it to the shop.
Upon a quick inspection, we found my timing belt was in absolulte shreds. It actually shed the top portion of 1/2 of the belt - the other part of the belt was like looking at a ball of string. Apparently, the water pump was leaking fluid, and over time, it caused havoc with the belt. The wierd thing is that the fluid level in my reserve tank never moved more than about an inch lower than when I had bought it.
I was sweating bullets, while we looked at some software to see if it was an interference engine. Thank god it wasn't. We installed a new Gates belt, and Master Pro select pump ( I work p/t at Oreillys).
I'm hoping this car sees 250K, as I might be piling up some miles as a courier (for the time being).
