E10 year round here with summer and winter blends. only ethanol free is near marinas where old boats would basically be destroyed by the effects of the alcohol on their ancient fuel systems.
The new generations of technology allow for injectors to fire multiple times DURING THE COMBUSTION STROKE, which eliminates the benefits of higher octane because the multiple injections eliminate pre ignition and actually allow for combustion pressures to be controlled and eliminate most of the issues with high compression. Direct injection also allows for higher compression which means more power all the time. Understand that high compression is ONLY that high with no throttle restriction and some new systems with drive by wire even allow the throttle plate to be wide open with power output controlled by fuel delivery, egr amounts, as well as sequential injections during the dower stroke, which can only be produced by direct injection.
The goal is HCCI , homogenous, charge, compression ignition, which means significantly higher thermal efficiency overall and much better mileage. The higher compression is part of a comprehensive system, but the compression it allows is the "longer lever" which makes the charge expansion during combustion produce more power on less fuel. This goes far beyond the slower rate of burn with premium fuel, which produced power generations ago with high compression engines.
Run what you want of course, just understand that if there are no demonstrable results in performance or economy, then you are just spending money for no benefit. E0 may give you 6% better economy but for a price increase of many times 6% it's not worth it and power levels can be matched without it. Indy cars run on pure ethanol and they make ungodly power for their size. Alfa Romeo built an engine the year I was born that produced 400 horsepower out of 90 cubic inches AT 2 MILES PER GALLON. Now we can enjoy unreal power levels with complete driveability, reliability and very good economy, which in the future will increase another 25%, without any other aerodynamic or powertrain improvements.
You buy 5 gallons of gas for one gallon of work, 20% average THERMAL EFFICIENCY. Compare that to the 56% thermal efficiency of the supersize container ships, with 4000 ton engines running at 92 rpm consuming 285 TONS of fuel per day (3 foot bore 9 foot stroke). If they actually use the existing technology then they could get close to that thermal efficiency and even beyond. The giant diesels in those container ships run on bunker fuel, the nastiest diesel possible, barely, if even refined. In WW2 Japanese diesel subs pumped fuel into their tanks directly out of the ground, through a filter, unrefined.
The premium gas myth lives on, even my 98 year old father runs premium. I tell him it's a waste, he keeps buying it, so I don't expect to convince anyone here to not waste their money. Last trank in my 19 year old Echo was 50 mpg. I run the cheapest fuel I can buy and can measure no difference in performance or economy, but I can drive differently and choose different roads that are deserted and with no outside influences as far as traffic and no low load driving I can get a measured 120 mpg in my Echo by using pulse and glide techniques. I can demonstrate that to anyone who wants to call me a liar, just visit Williamsburg Va and contact me and we can ride in my car and I'll show you what I'm talking about and explain my patent, BUT I HAVE NO ENGINEERING DEGREE. IF THAT IS WHAT MAKES YOU THINK MY CLAIMS AREN'T ACCURATE THEN JUST IGNORE MY ADVICE. :grin:
