thicker oil in summer becuz it is more likely to heat up more and thin out, thinner oil in winter for easier flow on cold days...or you can just run the same oil all yr round and not worry about it, 5W20, 5W30, or 10W30 usually all 3 aren't too bad, cold or hot, sorta go by what you owners manual says
I also only have a 7-10 min drive to work, on cold days, before I had a turbo, I'd start it up, warm it up for up to 5 mins (or however long it took to sweep the snow off, and take it easy, usually before my trip was half done the car would be nice and toasty inside, and temp gauge would say all warmed up.
now with my turbo car, takes a little less to warm it up completely, but still I'll start it up before I sweep the snow off. if there is no snow to sweep off, I'll let it run for up to a min, depending on how cold it is, then take off. and I have a pretty heavy foot (especially for driftin the back way to work
), remember to keep your oil changed and clean when you do mostly short runs, every 3 months whether it needs it or not...unless of course you use synthetic, than maybe 4 months, lol.
