I'm working on doing the fog light mod and I was able to find the fuse box under the steering wheel but, where is box with the relays? Does anyone know where exactly it is under the steering wheel? Anyone have any pics of where it is?
Oops. Sorry. It's a 2009 Camry. I know it's right behind the cover under the steering wheel but, not sure how that cover is supposed to be removed since it's also attached to the hood latch.it would help if you posted what year and model car you have... that being said, the relays are on the back of the fuse box under the steering wheel (at least for the 05 camry)
Thanks LE05. I will try to get a service manual in case there isn't a DIY on here of the panel removal. A member posted a pic of where the relays are in another thread but, I tried contacting him a few days ago but no reply. :facepalm: Oh well. Here's a copy of that pic.i think there's a little miscommunication here!
The fuse box and relay box are one and the same. The difference is in the ease of access... because the fuses are on the front, there is easy access through the pop out panel. the relays are on the back of that same box and much more difficult to get to.
Chettaman, you are correct in that you will likely need to remove the dash panel to access the relays; no owner's manual will have these instructions because it's not intended for the owner to easily access the interior relays.
However, if you can find the service manual, it should have instructions on how to remove the panel. The hood latch cable can be removed from the hood latch, that is how it is done on the 05 camry to remove that dash panel. search around on the forum, there may be pictures or a diy of how to remove that panel.
