I need to replace my 2016 battery locates in the trunk. It died after not driving the car for awhile. I tried charging it and it won’t hold. Battery - Toyota (28800-28100)
Interesting, so any suggestions on how to buy the replacement?Yes and no.
You have 2 batteries in the trunk. One is auxiliary 12V battery that feeds electronics. One is hybrid battery. Engine is started by hybrid battery, specifically, by motor generator 1, that acts as generator or starter, as required.
12V battery is charged off hybrid battery. Hybrid battery is safeguarded, so if it falls down on charge to a pre determined low level, it will stop charging 12V, to preserve itself.
All in computers, friends, all in computers. Forgot how many, 17 or 21 processing units.
The person you're replying to said they have a 2012 TCH. You do jump at the 12v in the trunk for the 2012 TCH. Just had to do it the other day. See page 461 of the manual: https://www.toyota.com/t3Portal/document/om-s/OM33A41U/pdf/OM33A41U.pdfNo. You do not jump at 12V.
It is jumped via fuse box under the hood. It has large nut in the center, or copper bus. That's (+). Next, any known good ground on the engine.
Yes, you can do it.
What year is your car?
Any voltage below 11.7 is considered unacceptable by Toyota.
