Whistling/Whining/Siren-like sound when accelerating
87K views 39 replies 8 participants last post by  NchaRette
Hi - have 07 Corolla, 91k miles, AT very well maintained. I have found this strange thing and unable to catch the problem. Been to dealer but they stated nothing wrong but I am sure I hear it. Would have loved to catch the audio but its difficult.
After start and then I start driving.Initially all okay. After about 10/15 min., lets say I stop. From that point onward or after slowing down and accelerating this strange but hardly audible sound appears. It happens as I step on the gas. It even happens when I am cruising and stepped on gas. To give you a description of the sound assume you're driving and at a far distance you can barely hear a police siren but causes you to check rear, sides, front, etc just in case you need to give passage, etc. You hear it only when you're stepping on gas and that too while you're stepping on the gas, the sound increases and then decreases. It's as if you know some type of flywheel, some soft of spinning top, etc. started revolving rapidly and then dies down. Any leads - much, much appreciated.
Tranny fluid - 20k old, coolant : 90k old, engine oil: 1k old, brake oil: new, power steering: new, brakes:new. Throttle and upper body: cleaned. I checked the intake portion - there's no leak or oil droplets, etc.
Maybe the windshield rubber? I had almost the same issue but it was the rubber stripping around the front windshield that would howl whilst driving on the freeway
Any check engine lights?
Lots of cars' engines make whining sounds at certain speeds. Practically ever car I've been in with a 4 banger will make some kind of whining sound in top gear at medium-low speeds where the road/wind noise doesn't down it out, usually when the gas pedal is being pressed lightly. If it's soft, I wouldn't worry about it.
#9 ·
Question 1 : Yes
Question 2 : Sometimes. But here's the thing : the decibel and occurrence increased as of yesterday, post change of oil!
Question 3 : P.steering pump : No, Rack & Pinion replaced: No
Sound clip : Will try .. today. Very difficult to capture...
#7 · (Edited)
Some 2003~2008 Toyota Corolla vehicles equipped with the 1ZZ-FE engine and an automatic transaxle (ATM) may exhibit a “whistle” or “hoot” noise under light acceleration at 35 mph to 40 mph with the transaxle at normal operating temperature. ATM cooler lines have been modified to reduce this condition on customer complaint vehicles.
http://www.autoserviceprofessional.com/article/92202/toyota-corolla-musical-transmission
Some 2003-2008 Toyota Corolla vehicles equipped with the 1ZZ-FE engine and an automatic transaxle (ATM) may exhibit a “whistle” or “hoot” noise under light acceleration at 35 mph to 40 mph with the transaxle at normal operating temperature. ATM cooler lines have been modified to reduce this condition on customer complaint vehicles.
Excellent stuff, helps. The TSB seems to be till 2008 which will include my '07 too ? Would you have the TSB # by any chance?
So - what are my options here? Dealer will blatantly refuse? Check this out: http://www.tundrasolutions.com/forums/sitemap/t-71802.html Very accurately it describes the problem I have.
It seems there's a fallout into the 2007 models too at least for some... Mine is towards the beginning of 2007. Also, thanks to the link it seems only some hoses need to be replaced. How should I proceed explaining this to the dealer. If absolute no, can this be a possible DIY?
#13 · (Edited)
It's possible that your 2007 was built with left over parts however that's highly unlikely.
But going with it was, the dealer will likely have no problem performing the work.
The replacement is not of the hoses but of the metal cooler lines that come out of the transmission and connect the hoses to the transmission and radiator.
This can be extremely difficult to replace if your car has rust on those fittings at the transmission. If you don't feel comfortable just go to the dealer with the TSB number and ask them to perform the repair. It may fix the issue or it may not. Hopefully (for repair sake) that is the issue.
#23 · (Edited)
#21 ·
#22 ·
Wondering if my car's 2007 and having 91k miles will the dealer charge me? If they attempt likewise what should be my strategy to counter it? Finally, as hardtop highlighted rust can be difficult. So, looking at the pictures is it something I should rather live with than having the dealer fix it only to suffer more moving forward?
#24 ·
Invader - thank you very much. Against your 1st. response I had replied but I guess you edited/removed and added an even better response. Much appreciated.
  1. At dealership, will they be charging me?
  2. It could be that they refuse saying TSB is up to 2006, etc. How best to counter this?
  3. Referring to Hardtop's response and few others in this forum, would you recommend proceeding to change considering the rust issues? (Maybe you can take a look at the pics and advice?)
  4. I was thinking to tell dealership and request for their most experienced technician, who should do this to reduce the risk of damage to AT/engine when removing the cooler lines. Any comments, much appreciated.
  5. Should I, before going to dealership call Toyota and inquire as to why my 2007 model has older coolant lines ? Is there any number (US/Can) and will it help in anyways?
  6. Finally, I intend to do a AT flush using DIY process outlined here. Should I wait for the TSB to be resolved prior to doing it? OR, should I request dealership to do it as it seems from the TSB, the ATF should be topped/replaced?
#27 · (Edited)
They wouln't charge anything only if your noise complaint is confirmed, and if your Corolla is still under warranty.
Show a print of TSB along with your original cooler lines on your Corolla.
It's a pretty straighforward job, easily done with proper tools.
Calling would be a waste of time... The proof is under your hood and on TSB. Your noise complaint may be confirmed by test drive.
No real benefit in having them do the flush at the same time. You'd still have to pay them for labor.
#25 ·
I am not sure what you are looking at but you definitely appear to have the updated lines.
The second pictures shows the right side. You can see the straight bolted section and the downward swoop.
As stated before the TSB only applied to 2006 and was never updated meaning:
1. The cooler lines fixed the problem.
2. Newer cars got the correct lines.
It's extremely rare for a new car to get non superseded parts.
#26 · (Edited)
No, you are definitely wrong... On the second diagram, the revised lines which don't have the metal tubing section, are shown connected to the metal tubing that are clamped to the tranny. bminada has the original lines that have a short rubber hose section before the metal tubing to the radiator, as shown in the first diagram not connected to the metal tubing on tranny that is left untouched.... The revised lines are rubber hose all the way from the metal tubing clamped on tranny, down to the radiator. TSB also shows clamp used to secure rubber lines to rad base. bminada obviously has metal tubing section to radiator.
Take your time and study it well before disputing again.
#30 ·
I guess I shouldn't have phrased my question the way I did, but I get your point. As a follow-up, will the dealer really only perform a TSB for no charge if the vehicle is under warranty? At this point even an 08 is going to be out of warranty unless someone bought one that extended out to 7 years. Kind of a bummer if that's the case, as I'd have liked to get this addressed, but not in the mood to have the dealer try to stuff a ton of labor charge down my throat for something they know is a problem with a company-provided fix.
#31 ·
SaGa - looks like we're out of luck. Dealer confirmed me I'll be charged since my car (2007) is out of warranty. I agree to everything you're saying regarding TSB, manufacturer defect, etc., etc and I'm sure this thread would have been beaten to death in this forum and elsewhere but it is, what it is, what can I say?
Coming back to DIY, not sure how capable you're ; but I wouldn't dare it. Reason being : the rusted nuts, parts, etc are a bitch to take off and any damage there could severely jeopardize the AT/engine. What I would recommend is a very good mechanic who has worked in Toyota. The diagrams - "invader" provided are great but requires a bit of knowledge of technical drawing to understand, it's not night & day simple!
I think, I might have to bite the bullet here and take it to the dealer. At the very least, want to know how much it'll take.
