Why does Slip Indicator Light come on?
73K views 14 replies 8 participants last post by  lburton
When leaving a stop the Slip Indicator Light has come on and a warning beep sounds; the vehicle stumbles for a second, then recovers, light and beep go off. Intermittent. 5000 on car. Took it to Toyota service; no codes. Service claims I am driving too aggressive out of a stop and tires are slipping on loose surface - -not true. I am concerned because I read in the Forum issues with VSC that sound dangerous. Any similar experiences out there?
Tx;
BPL
2011 Venza 4cyl, FWD.
Bruce, What nhcycle is telling you is it will happen even on level ground when you push hard/very firmly on the brake pedal.
Try this on level ground with the car in drive, push hard on the brake pedal for a moment and you will see the slip indicator come on. This is because it was activated when you held the brake pedal down.
#9 ·
BrucePL The slip indicator can be sensitive sometimes. Could the streets you drive have a lot of oil on them? Could they have rainwater on them? Could you be a little heavy footed on the take off? Lots of things can make the car slip a little. I can see why you might be concerned about it. I don't think I have seen this issue come up on this forum except involving winter roads. I hope you can get a more serious answer out of your Toyota dealer. Wyovenza
I've done this a few times accidentally at stop lights. You get bored and push to hard on the brake and it engages. What it is really for is stopping, then starting on a hill. The way you use it is to press on the brake way firmer than you usually do. A little display comes up on the screen in front of you, telling you that it is engaged. Now you can take your foot off of the brake and the car won’t roll back. It is only disengaged when you press on the accelerator pedal.
