Searching the forums doesn't turn up anything similar.
Drove home Monday when I came back outside a few minutes later I could hear the cooling fan running. I thought - Don't tell me I left the thing running!
The motor was off and the key was in the off position but the cooling fan was running, the blower fan was running and the oil light was flickering faintly.
So I fiddle with the ignition but no luck. Tried turning the steering wheel back and forth and no luck. If I turn on something else, like the wipers, it will shut down. Put some graphite in the ignition switch and cycled it and finally got it to completely shut off.
But it still does this, killed the battery yesterday.
Could it be anything other than the ignition switch? Relays? I'm assuming the switch is staying barely on, just enough to power what is in the "on" position because it quits when something else is turned on. So like a slow drain?
But I've never experienced anything like this before...
