WOW! High mpg on 2005 Camry!
8K views 48 replies 21 participants last post by  zapp
I get fantastic gas mileage on my 2004 Corolla. Great car. So, when my wife's Buick died, we looked at Toyotas. Glad we did. Here's the latest: We just returned from our first trip with her new (2005 Camry XLE). I am shocked at the gas mileage. We got 39 mpg!!! It is the 4 cylinder (K&N air filter, Amsoil in engine & tranny). Is this typical for Camrys?
#9 ·
i just fill up when my gas light comes on..
anyways i was looking at this used car dealer site and he had a gen5 camry and he stated it gets 38mpg... so in km's with the 18.5gallon tank it would convert to about .. 1125km's per tank. I've never seen close to that with the gen5 or gen6 2az... honestly i see about half of that.
i usually only get 300 miles out of a tank, and i average 25-27mpg in my 2003 camry
ive had as high as 38 mpg on an all highway trip, but i do alot of stop and go short trip city driving since i only work 2 miles from home, so i dont typically get as good of milage as id like to get and am capable of getting
#12 · (Edited)
That's nothing if it's highway. The best I got was 44mpg, but it was all hwy driving.
Right now, my mileage is over 35mpg average. I get over 360 miles average per fill-up.
#16 ·
I do both highway and city. Majority city. Highway only going to work and going to gfs
My '97 Sable had an 18 gallon tank as well IIRC. But I was referring to his mileage on the Camry.
Oh. You quoted "Only 270 miles on a tank? Thats horrible." so I thought you were referring to my gas mileage.
i hate ALL of you for getting anything above 25mpg. I have an 05 SE I4, i live in NYC and its ALL city driving so i only get 20mpg... gah!
NYC here as well. Not only is it stop and go or just a plain parking lot, but the roads and driveways are horrible. Cant even lower the car without scratching the front.
#13 ·
We knew the Buick (2000 Limited, 125,000 miles) needed quite a bit of work/maintenance. However, when we determined it needed a transmission, we headed for the Toyota dealer.
After my positive experience with my Corolla, a new Camry seemed to be the best choice. They close early on Friday - 5:00 p.m. I called the salesman, he was willing to stay late.
The timing was perfect. We arrived at 4:58 p.m. When we came in the dealership, a lady was just walking out the far door. She was picking up her new Camry. She had just traded in a 2005 Camry LXE. The salesman showed us several new and used cars. But, we settled on the car that school teacher had just traded in. It is loaded (the wife likes it like that), with only 15,000 miles.
It was obvious my wife was getting great mileage around here. I've never actually calculated, but I will now. After getting the 39 mpg on our trip, I'm wondering what she's been getting around here.
#26 ·
the wind must have been helping you sail on your trip because 39 mpg is not normal.
#30 ·
damn when i had my 97 es300 (1mz v6 4 speed auto)
it got 23-27 on average, and i recorded a few 30+ tanks
hat car dia lot better on the highway, city ate it alive.
my 07 i4 se gets a solid 27 on just about every tank. got 29.5 on a trip through the mountains. and this is with my 225 tires over 215 normal se.
i got a trip set upp for july lets see how we do there.
but 39mpg is awsome that = hypermiling..
#33 ·
Bitterly Disappointed in MPG....
This is a sore subject right now.
I have a new-to-me 2004 Camry SE 4-cyl auto and am just checking MPG - I could tell it was not going to be a good story. I drive like the proverbial "little old lady", staying in right lanes, not exceeding 70 on freeway, etc.
I'm getting 24MPG, and that is about 40% "freeway" driving.
SO, I propose we interactively here do a "RX FOR BEST MPG" .
I assume the following obvious:
- Run a can of Fuel injector cleaner [or three]: Which one works?
- Change to New Spark Plugs {Which ones?}
- Check, Clean, or replace O2 Sensor
- New wires for new sparkies???
- K&N or other Cold Air Intake: Does the Camry mass air flow calculation deal well with the increased flow??
- Inflate tires to Max pressure
- Run the best oil money can buy
What else? And can someone fill in the questions in my list, because I have got to do something. My wife's 200+ HP Malibu 6Cylinder auto AVERAGES 28MPG...... and its a lot less expensive. Our Corolla does fine... averages about 32, got as high as 36.
#34 ·
ZAPP, Without question I'd say you need a tune-up but at 70 mph most cars mpg will drop quite a bit. Your Camry might not get as good mpg as some other cars but you bought it because it'll outlast most other cars by 100K miles......didn't you ?? My overall mpg in my 2009 was 30 point something on my last fill up. When you decide to do a tune-up only use wires and O2 sensors made by Toyota. You can actually buy OEM cheaper online than going to your local auto parts store. Dextron is good stuff to clean your injectors with. I'd change your plugs, wires, PCV, air filter, hoses, belts, thermostat, anti-freeze, and transmission fliud/filter all at the same time. You've made a good decision buying your Camry and if you take good care of it it'll take good care of you.
#35 ·
:rolleyes: That advice pretty much sucks. :thumbdown
Without question? Really? His vehicle's mileage would be my first question.
He doesn't have spark plug wires. :hammer:
I've never heard of Dextron. There is a Dexron transmission fluid that does NOT work well for cleaning fuel injectors. :hammer:
What exactly is the point of changing plugs, wires, PCV, air filter, hoses, belts, thermostat, antifreeze, and transmission fluid/filter all at the same time? Most of that has nothing to do with fuel mileage and the service intervals aren't the same either. :hammer:
#41 ·
that answers one question: the ECM cannot respond to increased airflow.
they need to consult with Suzuki: puny motorcycle EFI system responds to such changes - all in a day's work.
Hey TRD - i did my homework, just forgot to discount by the "Kool-Aid Factor" which is prominently displayed here.
I prefer reality.
#45 ·
if that were a good solution peachy, no Prius's would be sold......
if the camry doesn't cut the mustard, it will be trashcanned and replaced - like the lexus and the 4runner.
I don't marry these things and don't bow to the manufacturers like they're gods. its just a tool that works for me or gets pitched out
To be honest...
No matter how much we complain and whine, gas prices are still going to go up, no matter what we say. If you're that worried about gas mileage, get a 21spd huffy.
Just change your driving style and call it a day.
