I am trying to figure out whether the D8S scanner can open the coolant bypass control valve of my 2024 Toyota Camera LE (gas engine). Please share your thoughts or experience. Thank you.
Why would the scan tool call the coolant bypass valve The "AIR" bypass valve? It has nothing to do with air. How can you be sure that scan tool is actually opening the coolant bypass valve? It does not make any noise when it opens or closes.Activate the Air Bypass Valve."
