Appreciate the insight on panoramic roofs, glass removal, and rail work. Sorry, you have encountered problems twice but you took the initiative to self-repair as being a proactive individual.
I've read and also watched some other YouTube videos about the malfunction and costs. Initially was $12K and then Toyota dropped it down to $7K as there were numerous repairs to them. I have a 2023 Camry XSE V6 (8th Gen. XV70 refreshed/revision 2) where Toyota claims to have improved and somewhat resolved the panoramic roof problems along with a few other mechanical issues that were on the 2018 to 2020 Camry.
I had Toyota Dealership Tech use Toyota Techstream software to change the settings in the Camry ECM to permit the windows and panoramic roof to roll down/open using the Key FOB. However, to roll up/close the windows and panoramic roof must insert the key into the door as it was demonstrated in this here video. Cost $0 when you have your next Service appt. as I have the 2 yr./25Kmile Toyota Care, just ask to have it done. Don't let them charge you for a 5-minute up to 10-minute task.
Panoramic roof preventative maintenance is required.
Keeping the channels clear of debris, cleaning it nearly spotless to the metal, and making note of where the old lubricant was before completely removing the old lube. The type of lubricant used can be white lithium grease but I prefer not to use, the $40 Dupont MOLYKOTE® G-1033 Grease, or DeoxIT’s L260-DN1 grease a small tube is $7 and larger up to $30 - I use this.
Never use WD-40. Apply a light coat of lubricant fingernail thick as using an Acid Brush works great, easier than using your finger.
Items needed are nitrile gloves, paper towels, q-tips, a vacuum, an air compressor if you have one, a small toothbrush or soft test tube bristle brush, a dozen Soft pipe cleaners for cleaning out the rear channel, a mild degreaser, a few Acid brushes, painter masking tape as do not want to get anything on the car paint or interior such as headliner and a drop cloth or large leaf trash bag or something to place over the car seats.
Last, water or windshield washer fluid to know whether or not the drains are clear. Pour water into the channel and allow it to flow and drain. If the drain is clogged using Weedwacker line aka trimmer line .080 or .095 as may need 5 foot length or buy the
2.3M Car Sunroof Drain Dredge Pipe Cleaning Brush Dredging Brush Flexible Tool at Walmart store for $10 the drain runs through the door pillars to the rocker panel. Do Not force the line down, using the dull non-pointed side, push slowly as do not want to break the tubing made of super thin rubber. There are 2 drain holes, front and rear on each side of the roof. Importantly, Do Not use compressed air into the Drain Holes as may blow out/separate the tube in the Door Pillar, and then water will travel inside the car cabin and onto the floor.
for the outer rubber seal around the panoramic roof I use Sonax 03401000 Rubber Protectant GummiPfleger, 3.38 fl. oz. , black also on the door seals/gaskets.
Thanks again for creating the video. Your TRD looks Kool! with the racing stripes.
must have repainted the wheels white to maintain a complementary color.
Happy New Year 2024
2023 Camry XSE V6 purchased in December 2022, photo taken on Nov. 30, 2023.
Installed Hood Lift Supports (replaced the Prop Stick/Rod) and Front Upper Strut Brace. Photo taken on March 24, 2023.
