My engine-side air filter (CLEANER ASSEMBLY, AIR; 17700) suffered two problems and now I am unable to close the box.
So, visually, the air filter Is sandwich: the top and bottom pieces of bread are plastic and the meat is the filter inside.
One edge of the sandwich is held together by a fitted hinge. No problem here. ✅
The opposite edge of sandwich should be held together by a bolt on the top (BOLT, WITH WASHER; 9009904593) and a nut on the bottom (NUT; 9009905286).
My problem is that both of bolts snapped. This means adding a new bolt has nothing to screw into. And also the nut cannot be removed because it is arrested in place. 😳
Obviously, one option is to replace the entire assembly (OEM currently out of stock; and this may be excessive).
But I wonder if alternatively there is some kind of all-metal C-clamp that can keep the sandwich closed.
Any ideas? Anybody seen anything like this?
