So I have an issue with my 07 Camry I4 (2AZFE) 203+ miles. It starts fine when cold (sitting overnight) BUT when its driven and the engine warms up. Whenever I try to start again, it takes a longer time to start. It will crank a few times before it starts. It always starts however it with crank extendedly before starting. It drives perfectly after starting though, no idling issues, etc. No CEL either. The issue is only the extended cranking before it starts after the engine reaches operating temperature.
Cleaned MAF & throttle body, changed air filter and PCV valve and hose. Brand new battery. Had stater, distributor and battery check after chaging the battery and everything was ok.
What do you guys think is the issue?
