I have a 4cyl 5-speed Camry with about 256k miles on it. This is kind of an odd problem and I haven't been able to track it down yet.
When I go to start my car, regardless of engine temp, it will have a hard time starting. If it does start, it will run very rough and then sputter and stall. When it fails to start or run smooth, I turn the ignition completely off then try to start it again. Eventually it will start up and run flawlessly. It will sometime fire up on the first try, and sometimes it could take me 20 tries before it runs. I've checked the battery terminals and they're clean and tight.
Does anyone know what would cause a starting issue like this? Once I get the car running the check engine light does not come on so I haven't been able to pull any codes, and once it's running I haven't had any trouble out of it.
Thanks for helping out a first time poster! :chug:
