Can I install a 1MZ-FE engine in a 1997 Toyota RAV4? Will it hook up to my exsisting gear box? :hammer: It has a 3SFE 2.0 Engine, a 5 speed gear box, 4 door, 2WD vehicle.
:lol: :barf: :lol:B Deuce said:the first drink that ever made me throw up at a bar.
The 1mz-fe and 3s-gte+turbo/etc. are almost exactly the same weight. Aluminum open deck (1MZ) vs. iron closed deck (3s-gte).Siver_Cartel said:why the hell wouldn't you do a 3S-GTE??? Wouldn't 1MZ be heavy as hell and f*ck up your handling real bad?
yup, i took a sip and before I could swallow my head was in the trash can.alltrac165 said::lol: :barf: :lol:
the older cam with 2VZ-FE and 3VZ-FE, what tranny did they use?? and the older 2nd gen used 2VZ-FE with manual tranny...would those mount on the 3VZ-FE since they're considered the same engine family.?B Deuce said:3SFE-5SFE - same engine family. 5SFE is the newer engine, and has bigger displacement (2.2L vs 2.0 in 3SFE)
IIRC, 1MZ and 5SFE trannys are different (A141 on 1MZ and A140 on 5SFE autos) so if the RAV4 did have a 1MZ dropped in it, you'd have to buy a v6 tranny to go with it. As for whether or not that tranny fits, depends on the following: RAV4 is on a shared platform/frame (think Camry/ES/Sienna/Highlander/Avalon), but I don't remember if its off the Corolla or off the Camry. If off the Corolla, there will be one helluva fitment issue. If it's off the Camry, it should drop in, unless its one of the AWD RAV4's then its a whole different issue.
Wow! What kind of labor rates do you pay? I did my own layout for the custom motor mounts for my 1JZ swap. I took the cardboard templates to a local weld shop and had them make them. Total cost: $40.Eye8Pussies said:with the 3sgte, you won't need to make custom mounts, which in themselves will run you a couple grand for good ones to make the 1mz fit properly in your engine bay
