A few questions about brake shields (backplate)
16K views 20 replies 10 participants last post by  Bitter
I was doing my front brakes and rotors this weekend and noticed when I took the driver side rotor off that the brake shield was completely gone. On the passenger side, the shield was still there, until I hit the rotor a few times with a mallet to remove it. That was enough to cause the shield to crumble and fall off!
So my questions:
1. How necessary are these shields? Yes, I live in Canada...so snow and ice and salt and nastiness all around.
2. How hard are these to remove and install? Do I really have to pull the whole hub assembly to get at this part (or what is left of it) and to install a new one?
3. Any idea how much a dealer charges to do this?
4. Is this amount of corrosion normal? My other vehicle (Honda) is 17 years old with over 400K kms, and the brake shields look like new.
This is definitely not something that gets complained about often here.
Removing them requires disassembling the car and removing the hub from the steering knuckle/spindle. This is labor intensive. As for what they do, it really is just a dust shield for debris behind the rotor.
Can you post a pic of what you have left?
#3 · (Edited)
I believe he has basically nothing left except maybe the sleeve part still wrapped on the steering knuckle... My bro's 2005 was the same after a couple years in Ottawa's winter road salt. I just ripped them off when I replaced his rusted out front rotors. Then his driver's side front wheel bearing seized up from rust buildup within... You're fine without the rotor guards though. I recently replaced the original front rotors on a 2006 Mazda 3 GT which never had any.
I did not take any pics while working on it. If I decide to tackle this shortly, I will take some pics of what is left. Basically just the torx bolts with some rusty bits of metal still held down behind them. Everything else is gone. Unfortunately, I just had the drivers side bearing replaced last spring. Perhaps that is when I lost the shield? I didn't notice it missing when I cleaned the brakes in the spring, but I may have just overlooked it as I did not pull the rotors off. The passenger side bearing now seems to be on its way out, so I can at least get that side replaced.
Ottawa winters seem to be particularly hard on this vehicle. It is a 2006 with just over 100K kms on it now. Is it normal to be replacing bearings already? I've also had the exhaust pipe snap due to corrosion. The body is rust free so far, but underneath is starting to worry me. As I posted earlier, my 99 Honda has 400K kms on it, and I have never replaced a bearing, exhaust system is still all factory, and the brake shields look brand new. Maybe I've just been spoiled ;-)
It's too bad that there is no two-piece aftermarket shield that could be installed without the need to remove the entire hub. I've seen it for other vehicles, but haven't found one for the Corolla.
The parts are 4778112240 (right) and 4778212240 (left). Toyota's SRP is $24.85(US), but can be found cheaper. Not too expensive to experiment with cutting, but are there only three bolts holding them on? I thought there was a fourth. If that is the case, one half would only have the one bolt holding it on. I was also curious how tight the collar of the backing plate fits between the steering knuckle and the hub assembly. Is it possible that some of the rusted backing plate material could still be between the knuckle and hub?
#13 ·
I'm sure whatever is on the backing plate will crumble apart with ease.
When compared to leaving them off or removing a hub, I'm going to cut them. I'm sure they will be fine secured with one bolt.
#14 ·
The knuckle has to be removed and the hub pressed out to access the bolts that hold the heat shield on. Might as well put new bearing in while you're in there!
I have in the past on some cars been able to remove the hub by using a slide hammer and then reinstalling it using a rubber mallot to get it started and pulling it in the rest of the way with the axle nut but there's a good chance of damaging the bearing in the process. The outer race will most definitely be stuck on the hub and if the bearing is worn all the balls can fall out when that happens. Also after reassembly it's likely the life of the bearing will be compromised due to a change in preload... but it might be possible. Not really worth the risk in my opinion though.
#17 ·
My $0.02 and a BTDT. Just cut a segment out of the replacement if you're referring to the fronts. Used an electric cut-off tool. Since I'm in Rust Belt, used some moly grease on cut and also on hub to facilitate wheel R &R. Not going to worry about the shield rusting! Evil PO of my 04 CE has some kinda accident and left remains on hub, so I only replaced the one.
#18 ·
I had them on my odyssey. When one rusted off and was banging around, I just ripped it off. I ripped off the other side at the next brake pad replacement (to even things out). I never noticed any difference in braking. It was weird that honda only put them on the back wheels. These shields can't be helping the rotors cool by not letting air from all sides hit them, so I say off with them.
#19 ·
dude i'm from Ontario, the only province to use salt on the roads and both of mine rotted off. It's like it came from Titanic.
I don't think they are necessary. I think all they do is prevent stuff from flying on the rotors. meh . i think u can go without them
#20 · (Edited)
My $0.02:
Car makers don't add unnecessary stuff unless its a requirement. Those shields help in wet weather braking IMO. Racers usually remove them to keep temps down.
Digression: My father told me to dry my brakes (back in the day when discs were not standard) after crossing a local ford. About 15 years ago, some guy in a Mustang? IIRC, coming back after a night at his country club, went off after that ford into a tree, ending in his death, along a parkway. Speed was also big issue. I seldom drive through fords (the water crossing or other), but if you remove or have corrosion remove your brake shields, you might consider adding a slight brake application to dry off discs after saturation? YMMV.
