I just did this. Here is a full guide to what I did. Pictures included.
I don't know if this is the best way. But this is what I did. Correct me if I'm wrong.
In the "change holder" behind the e-brake you want to lift up that little piece of carpet in there and remove what I remember is four screws. Follow that center console trim up and near the floor just before the shifter you should see a blot on each side of the console. Take those out. You should now be able to remove this. I tried to remove the trim pieces on either side of the shifter but couldn't figure it out. Don't worry I still got it done.
There should be a rounded that is directly around where the letters are. Carefully pry this out. Since you did that. The plate where the shifter slides up and down through and where the PRD21 are written should now be exposed.
This was the most difficult part. Make that the second most difficult (hold that thought)
If you look around this plate you will see four tabs. NOTE: I FOUND THE TABS WERE BEST REMOVED FROM RIGHT.....RIGHT TO LEFT. I almost broke this. Pop the top right one and pull up a little on the plate, pop the bottom right tab, and it should swing up from the right side and by doing so, slide out of the setting on the left. You then turn this plate 180 degrees and your light is exposed.
Now. I had never changed a 194 bulb before. I assumed...I now feel like an idiot sharing this story, but I hope some of you take enjoyment from this. I laugh now. Lets prevent another mistake though.
I assumed the 194 bulb unscrewed... DON'T DO THIS. The 194 bulb can be pulled right from the socket no different from you're regular fuse. Since I unscrewed the socket from deep in the setting, and couldn't get the side trim pieces off. I FOUGHT THAT FUCKING SOCKET FOR 40 MINUTES BEFORE I GOT IT BACK. So... Be smart, pull out, push the new one in, and be done with it. Also. Thoroughly test your new bulb by switching on your headlights before you replace everything. Just follow these steps backwards to put everything back.
Also, your e-brake is also easily tightened with the console off. Just loosen the top nut on the cable. Once loose, tighten the bottom one driving the cable up, then retighten top nut.
In this picture the round thing is what you want to get off before you can get access to what I referred to as "the plate"
This is what the 194 bulb looks like...
What it looks like when the center console is removed and the bulb exposed. Notice how I rotated "the plate"
And this is a closeup of the bulb, in the socket, deep in the well. It was a pain getting it back up in there. Don't remove the socket. Just the bulb. If you removed the socket I hope you have long fingers.
PM me or reply here and let me know how it went.
