Been awhile. Tons of progress on my Camry. Have an appt on Thursday for an alignment and she should be good to drive.
However since I did so much work to the engine and replaced my 5spd with a lower mileage unit it made me want to check everything else out. So I went to check/set my ignition timing (I earballed it before, I'm fairly good) and happily my timing light has a Tach seeing as the eBay cluster I bought had a non functioning unit.
I fired it up, let it get nice and warm and saw that my timing light was reading 1100-1200rpm for idle, it didn't necessarily sound that high but I've also never heard another one of these cars in person, but in videos it seems to be pretty on par with others. Timing has to be 5deg @ max 950 RPM (w/ vac adv disco'd) so I couldn't set the timing. I also blipped the throttle a few times to try and trick it to idle lower but no luck. Spec is 700 M/T & 750 A/T
What all else should I look at before I go turning the idle screw on the TB? I'm thinking IACV for starters. I don't have any vacuum leaks that I'm aware of. I've gone over them several times in the past.
Anyways, have some 1st gen
