Very helpful, thanks. Just to be clear, you got your 2005 Corolla NEW and the notched pin was in the bottom position straight out of the factory?
In the parts diagram, the diagram doesn't show a notch, but it's just a drawing. It does show "MAIN" for the bottom and "SUB" for the top. My current understanding based on photos I've seen online is that the "MAIN" slider pin is the one with the notch and the "SUB" slider pin is the one without the notch. The main difference between the two is actually not the notch, which I think was for identification purposes for the assemblers of the car (not sure). The main difference is the taper and length of the facets are quite different. Here, look at this:
One thing that has me thrown for a loop is WHY the top pin is identified as "SUB" and the bottom pin is identified as "MAIN"? That makes no sense to me. To me, "main" would be at the top, and "sub" would be at the bottom, BUT Toyota must have a reason for that which is above my paygrade. I just spoke with a Toyota parts counter guy and he agrees that it doesn't make sense, but verified by sending me the diagram which shows this below:
Here's the diagram showing the "MAIN" slide pin is positioned at the bottom, and the "SUB" slide pin is positioned at the top:
