I was at the junkyard today and noticed a 89 with the struts taken out of the front, then noticed the top hole in the knuckle was alot bigger than the bottom one and then found on the ground 2 eccentric adjustment cams with the bolts still in them, you can adjust the camber in this car!!!! I looked at all the other camrys and they looked like mine with no cams on the bolts but did notice some corollas and tercels with cams, is this something the owner did or was it factory because i do not remember ever seeing one of these cams on any camry?
