My 93 LE has 114k on clock and up to date w/ maintenance. A few months back, I removed and cleaned my ICV and since then my car idles high.
On start up, it idles at about 2k plus rpms and when the car reaches normal temp, it idles around 1500+ rpms in park. When placed in drive, it drops down
to around 1k rpms.
Last weekend I replaced the ICV with one I pulled and cleaned from pull a part
and still idles high. Today, I replace my thermostat thinking it might be the problem, but car still has high idle.
Prior to the start of the problem, car would warm up and idle at 750 rpm in park or at stop sign etc.
High idle is causing about 4-5 mpg loss looking for any ideas on what else I can check or replace to solve problem with this idle problem.
Thanks in advance!
to around 1k rpms.
Thanks in advance!
