Hello all,
I have a set of JDM floor lights that light up the foot wells. They originally come with a control box that uses the dome light circuit to turn them on, but once the doors are closed, they stay on for 10 seconds then proceed to fade out. My control box seems to have broken (lights don't work at all, but all the wires show proper continuity and bulbs work when powered directly), so I want to replicate it and custom wire the floor lights in. Yes, this isn't for the dome light, but it's the exact same principle and most people would use this for the dome light.
I see people making those circuit boards to get the delay and dim effect, but I don't understand how to make them. I have very little knowledge on advanced wiring like that, especially not knowing exactly what transistors and such are. I hope some of you can help me understand the most simple way to achieve this just by using a 12V power and ground source, and two wires going to the bulbs (positive and negative). Also, I don't know if it makes a difference, but I'd like it to work with both LEDs and incandescent bulbs.
I found this. A bit pricey, but could it work for my purposes? Or is it better to make your own? I'd prefer a small size of course.
http://www.ebay.com/itm/DOME-INTERI...ssie-Made-/330956606783?pt=AU_Car_Parts_Accessories&hash=item4d0e8d0d3f&vxp=mtr
Also, one last thing, I saw someone selling a relay to induce a delay. I assume that's not how our car works? We can't swap a relay with a built in delay and dimmer function?
