Engine temp question
2.6K views 35 replies 7 participants last post by  Pete Suhman
HI,
Its wintertime and the corolla doesnt seem to be kicking out much heat. My f150 will burn me out of the cab while the car doesnt.
Temps are anywhere from 0 to 30 F out. Car is warmed up going down the interstate.
Looking at the temp gauge the needle is barely touching the bottom of the icon.
That icon is right in the middle of the gauge. I did put a piece of cardboard in front of the radiator and it raised a little but not much.
Bad thermostat?
The are very straightforward to change. Follow the bottom radiator hose to the engine and where it connects is the thermostat housing.
A couple of things to be aware of:
- Get a new gasket with the thermostat.
- Be aware of mixed quality thermostats out there. Sometimes they are bad right out of the box. Safest bet is going to be OEM but there are several users here with aftermarket thermostats that work great. But I've seen it here where they've been defective right out of the box too.
- Obviously get the right temperature opening. Can't recall what that is :)
- Bleed the system with the radiator cap off and heater on full blast.
Wait - I re-read your first post. You're saying the needle is touching the bottom of the icon in the middle - so it's sitting pretty much at the 9 o'clock position?
If it sits there and doesn't fluctuate once warmed up it's not the thermostat.
Sorry I thought you were saying the needle was at the bottom of the gauge.
Sounds more like a gummed up heater core. A reverse flush with radiator cleaner and fresh coolant should do the trick.
#27 ·
Here is what I found with pics. I got the car up to temp
I checked the engine temp on the upper radiator hose:
Temp at the thermostat:
Temp at junction by firewall:
The junction box moves fine. No binding in cable.
#32 ·
160.4Âş sounds a little low to me. Shouldn't it be closer to 185Âş or 190Âş? I had a car into which I put a 160Âş thermostat, and that car had hardly any heat. Maybe the 'stat is in the beginning stages of sticking open, and that particular 20Âş doesn't produce much sweep on the gauge?
#33 ·
That is true. I was just assuming there was some insulating capacity in the hose but what do I know. Now that I think about it the gauge temp pic also shows SLIGHTLY low. Not bad. But slightly low.
I still think the main issue is circulation. But if you go through the effort of a full flush you might as well throw a new thermostat in there given the slight variation.
#34 ·
to 100% make sure the thermostat is working, check to see if the cooling fans are comming on. its winter, and so they wont stay on for long, but they will come on as long as engine is up to operating temp, no matter how cold. the heater core may be gummed up on the inside, or there could be physical debris blocking airflow on the heater core itself. like someone else said, a blend door on the inside could be malfunctioning. but if theyre getting up to at least 160 on the temp gun then you should at least be feeling comfortable with the heat on. it may not burn you like your truck, but thats pleanty to produce an 80* cab temp
#35 ·
160F is a bit on the low side; however, we don't know his outside temperature is and how long the car ran and idle. Not sure how long he had the car, locally here there were some car came with 160 degree thermostats. I am just curious why there is close to 30 degree difference between the engine and the heater core inlet hose, it should be relatively close since the coolant just came out of the engine. It is as if there is not enough coolant flow through the coolant flow control valve; maybe the valve is not fully open or the heater core is restricted enough that it restrict more coolant from entering.
#36 ·
The engine might've been cold when he started it, and it hadn't run long enough to warm everything completely up, when he snapped the pic. That would also explain the 160ishÂş temps at the thermostat housing, in light of the nearly normal position of the gauge needle.
