How to adjust brake
1 reading
2.4K views 19 replies 6 participants last post by  camlex
Good evening, Team,
Lately I feel my brake Padel is feel soft and it's going further down then before.
i read somewhere that while backing up your truck pushing brakes help self-adjust rear drum brake.
I tried it, but still feel same.
How to adjust without too much trouble.
Thanks in advance.
Using the parking brake auto-adjusts the drum brakes. In order to adjust them, you need to get under there, remove the rubber cover, and adjust the adjuster. Or just dona full brake inspection.
There was a time this was true, I cannot say if it applies to your model. I was once instructed to stab the brakes firmly while reversing about 5mph. If the pedal height doesn't return after a few stabs, the adjuster may be seized. They get washed down with every rain, so they do tend to rust up. in that case the wheels/drums have to come off.
How many click needs turn because tires will be ground.
You really need to adjust them with the wheels off the ground. If the adjuster is seized, it needs to be freed up first. Adjust them as to extend the adjuster out between the bottom of the shoes forcing the shoes until the drum just barely drags. If you adjust it on the ground, you are going in blind and may be over adjusting causing unnecessary drag/wear.
A soft pedal is not the same as a pedal that has lost height from an out-of-adjustment rear drums/shoes. If the shoes need adjustment, yes the point of stepping on the pedal to it actually braking does increase, but the pedal should still be firm once the pads/shoes are making contact. If it is soft you either have air trapped in the system or a rubber caliper line is swelling and about to fail. I would inspect the entire system and bleed all 4 corners before I even bothered trying to adjust the rear shoes. You may also consider getting some test strips to check the fluid for water or high copper levels....
And if you’re asking about how many clicks while they’re on the ground, read up more on adjusting drum brakes. You adjust them to where they start dragging then back them off a little. But I suspect it’s time to flush the system. The first time I did it was too long and there were air bubbles in the rear. As fluid breaks down over time/use, it allows it to boil at a lower temp creating bubbles.
my truck has the classic old-man cane lever for parking brake, pull out under dash
i think you sport a left foot brake for the parking?
does your rig move any on an incline if in neutral out of gear with that park brake full depressed
My mechanic adjusted it. Wow. What a big difference. Only thing I noticed is missing those rubber plug
Is it okay to leave open?
Buy and what’s part number?
Thanks
I would not leave uncovered but because I am in the saltbelt and don't want slop getting up inside of there
#11 ·
#14 ·
I see your lol and raise you a HA! My '72 Dart has had a piece of Gorilla brand duct tape covering that hole for 3yrs now!
#17 ·
sell them for $2 each, covering postage, to interested members. ~$1. profit (how much is postage these days?)
