My 93 Corolla is failing inspection because of high HC ppm, and I'm wondering how I can get it to pass. So far since it failed the first time I replaced the catalytic converter, distributor cap, rotor, air filter, went back, and failed again. I have also recently replaced the spark plugs and wires, PCV valve and grommet, cleaned the throttle body and IAC valve, replaced fuel filter, water pump. I also recently did a head gasket job, so it's got all those new gaskets.
The HC ppm is supposed to be 220, and I'm at 606. Her are the other readings too- CO%-0.22, CO2%-14.2, O2%-0.9
