Sure it's basic, but damn if I didn't wish I'd read up on it here first, heheh, so feel no pain in asking. I'm definitely guilty of breaking those stupid things when I went to do my plugs.
My advice to you is remove the bolts that are towrd the front of the cover (Note: one is a captive bolt, so you'll end up pulling out the whole bolt from the head, so don't freak out when you see that while you only get the nut on top to come off of the other side, it's completely normal). After you've removed those, just grab two good handfulls of the engine cover and try to pry it up. It decreases the likelihood of breaking those brittle plastic fasteners, even if it may take you a few tries to get the cover off. If you try to pry the fasteners out of the cover you'll very likely snap the heads clean off and then have to pry the plastic threaded portions out of the head with pliers (like I did).
When you go to reinstall, just keep pressure on the plastic heads of the fasteners when you go to press them back in place (after partially threading the real bolts back on, or at the very least getting the captive one started so you don't have to fish around trying to blindly find its hole later). Once those plastic ones are home, finish bolting the real bolts back down, alternating between the two every few turns to keep things even. Don't overdo the tightening on those either, or you'll just be warping the plastic cover. Once they're snug, you're done and it's not going anywhere.
