So, i replaced my headlamps with Sylvania Ultras like a week ago and it wasnt as bright as i expected. So i did some research and learned about an interesting idea. To use external relays directly connected to the battery. So the suggestion goes like this, You plug in the new 40 amp relays to the wirring harness that connects to the headlights and use your regular light switch to control them. Then you draw power directly from the battery to the relays to the headlamps. The whole setup is using heavier cables then the factory harness 12 or 10 gauge.
What do you guys think? Has anyone tried it in any of their cars?
I'm thinking about taking it on and letting you guys know the results.
