I've been searching these forums and the internet for the answer to this one . . . the answer may in fact be "there is no way to tell where the door control receiver is located on a particular Camry." I am hoping that is not so. Here is the issue:
Factory door remote on a 2006 Camry began to fail. Problem was intermittent at first. Replacing battery did not help. Eventually, remote stopped working altogether. Second factory remote, rarely used, was tried at this point and also no response. Attempted to put the vehicle in reprogramming mode to see if that would cause the vehicle to recognize the remotes. However, after the final step to enter RM instead of the expected response (cycling of door locks) a soft "beep" is heard from somewhere inside the cabin -- it is soft and quick so it is hard to pinpoint. this happens repeatedly, but will not happen if the fuse for the DCR is pulled. My belief is that this beep is coming from the DCR and is an indication that the unit is malfunctioning and cannot enter RM.
Dealer has indicated that there will be a $195 diagnostic charge (though I suspect they already know that its the DCR) which they will apply to the repair. The part retail is $588, so I'm guessing that the 195 is the labor charge. I'd prefer not to shell out $800 to get this problem fixed and figure I can get a DCR used or aftermarket for less than what Toyota wants. Problem is, I can't find where the DCR is located.
So please, if anyone knows where the DCR is (hopefully, given that this appears to be a fairly common problem, you've actually pulled the panel its behind), I'd really appreciate being clued in . . . This is my mother's car and she will be very impressed if I can fix the problem for her
An old thread on this site (http://www.toyotanation.com/forum/1...eneration-2002-2006-2007-2011/326864-how-install-factory-alarm-05-06-camry.html) indicated it is in the rear passenger side pillar -- I also found a diagram that indicated this . . . if that is so, I will need some guidance on removing the rear passenger side pillar without damaging it . . . thanks
