So my girlfriend's matrix has 211k miles on it, not that well taken care of until I came around. She needs it to last another two years through nursing school, so there is an exhaust leak, and some sound from the exhaust manifold. But before we get to that the motor mounts need replacing.
The passenger side MM more or less flopped when taken out, totally broken
Drive side MM had a crack in it but is in the best shape of the mounts
Front MM has some play side to side but front to back is good, has minor cracking
Rear MM has large cracks
All the mounts except the rear motor mount was a breeze to take out and replace. The rear was a huge pain to take out literally took me an hour, and the aftermarket one was a pain to get in and then even worse to get it lined up. It took some filing and hammering to get that part to a better fit, took 5 hours with filing. It was nightmare but it was done. So I put the car down and the engine shakes quite a bit back and forth. I'd guess movement is 1/2", most noticeable on the passenger side motor mount. She bought the el cheaper $15 each motor mounts, I'm guessing even though they didn't budge much by hand the motor moves them more than I could. Interestingly, I put the car back on jacks and the motor doesn't vibrate since it's at a slight incline. I retightened everything once I jacked the motor so the bolt would go through the mount. Perhaps I need to let the motor sit differently then tighten the bolts?
OEM toyota parts are on their way, since she needs her car as her DD, I need to get this fixed ASAP. I'm going to swap back in the better old motor mounts until the new parts come in. However the rear is going to be a huge pain, to get in and out, really not sure if I can get the OEM one back in. Any tips on how to fit it in? Also do you think she can drive with a bit excessive vibrations, as her old motor mounts were shot and the car vibrated hence why new MMs.. Also anybody have the FSM for an 06 matrix AT so I know the torque specs for all mounts. I saw 2 other topics with torque specs but only for 2 of the 4 motor mounts.
Thanks for the help
Thanks for the help
