NGK and my owner manual spark plug listing are different.
5.4K views 18 replies 7 participants last post by  hardtopte72
2004 Camry with 145000 miles.
NGK website lists 1fr6T11 for my 2004, 4 cylinder Camry. That what hardtopte72 has in his maintenance thread. However, my owner manual lists 1fr6A11.
I capitalized the letter in question.
According to the NGK, letter A stands for “Special Design”, and letter T stands for 3-Ground Electrode. There is obviously a difference! Which one should I choose?
Does anybody have more information?
Sam
#11 ·
^ The trivalent coating is a one-use only coating. Once you remove the plug, that trivalent coating is useless.
So if old (or new) plugs that were removed for any reason should have a coat of copper antiseize applied if they were to be reinstalled. I'd even put dabs on new plugs. Clearly YMMV.
The NGK article is concerned about over-torquing the plugs. But for these engines I would say a dab or two of COPPER antiseize and then torqued to 13 lb/ft will work fine. This is what Honda recommends anyway. The 13 lb/ft I take it was taking into account the antiseize on a plug that otherwise requires 18 lb/ft, which is the lower range of what NGK recommends.
I wouldn't torque it to 18 lb/ft with antiseize however.
#17 ·
I asked NGK the same question and they confirmed that THEY recommend 1FR6T11.
I then asked Toyota tech support and they confirmed that THEY recommend NGK 1FR6A11. They sent me a link for the updated part numbers. Here it is:
http://www.toyota.com/toyota-owners-online-theme/pdf/09_SparkPlugs2014_final.pdf
Since there is no confusion with Denso brand I will probably go with them. I still will try to see how much my local dealer wants for NGK though.
Sam
#18 ·
Id go with the one that is listed in your owner's manual. The difference is in the firing end of the plug. It may not make a difference, then again maybe it will. When it doubt, go with that the owner's manual says.
#19 ·
No, they literally are the exact same spark plug. You actually cannot buy the "A" plugs anywhere but Toyota. That is a manufacturer specific number.
You will not find a single person anywhere that had an issue using an 1FR6T11 spark plug in any engine "spec'd" for the 1FR6A11 plug.
