Power Steering Hose Leak?
2.6K views 7 replies 8 participants last post by  Kingdom934
I was changing the oil on my 2004 V6 Camry today and noticed some wetness around the power steering fluid reservoir today. It appears to run down the smaller of the two hoses coming into the reservoir. The leak does not appear to be heavy but enough to make the tube look wet. I am wondering if maybe the last few days of sub -20F temperatures had anything to do with this new leak. Or could this have been caused by recent dealership work where the struts and coils were replace because the coil on the passenger side snapped. Anyways I understand Toyota does not sell just the rubber hose but the whole replacement line.
I was thinking of maybe going to a pull your own parts and finding a Camry of similar age and just pulling the tubing I need. Thoughts on cause and path forward?
I have a similar leak on my wifes 06 Solara and I wonder if the standard low pressure side power steering hose could be used. the rubber hose that is on there is held on by standard clamps. If it is a standard size I would think it could be replaced with a short piece of hose and new clamps
Does anyone know if it is a standard size or as my usual luck an odd ball size?
I saw a similar post on here about this issue.
My 2009 had leakage around the low pressure hose and fluid level was down. I replaced the band clamp with a screw down type and cleaned up the area with brake clean. Its been dry since then.
P.S. hose
My 04 leaked at the reservoir fittings after a very cold winter in 2015. Given the age of the hoses and clamps I replaced the feed hose to the pump and the upper return hose ( which includes the 2 rubber hose ends and the metal pipe). I ordered the parts online from Toyota of Texas Grapevine. I got a very good price and a flat shipping charge. My local dealer couldn't touch the price.
The power steering rubber hose on the Metal line goes from meta line to ps res is some funky side. No wonder Toyota doesn’t sell it standalone (I don’t know why really) One side is smaller than the other side. You can get a “‘compatible” size and stretch it on.... I had to do it to my 1998. More of an annoyance really.
