On 2001-12-07 12:34, SpectraBlueCam wrote:
Yep it fits! BTW, my TRD wheel is on. It looks amazing. :grin: But it has to pass the ultimate test: resetting the airbag light.
Where did you manage to find a Celi wheel? Damn! I've been looking for one!
Tip number one is not to disconnect the airbag with the ignition on. That will set off the airbag light (which is what happened to me). One way to avoid this problem altogether is to disconnect the battery, which is what Haynes recommends.
When doing the swap, you'll need to splice the airbag wires to make the connections. We'll get to that when it arises.
As for removing the wheel, here are the instructions (which ARE in the Haynes manual) :wink: :
1. Pry off the two flaps on each side of the wheel (one around the cruise and a blank one on the other side).
2. Undo the torx screws (I have the torx bits if you need to borrow). Note here that the screws do not come out because they're held in place. Just loosen them all the way.
3. Yank out the airbag module.
4. Disconnect the airbag harness.
5. Disconnect the horn/cruise harness.
6. Unscrew the big lugnut in the middle of the wheel.
7. Whack the wheel from behind to get it off the hub.
BTW, get a GTS wheel if possible. It's leather wrapped. All GTS wheels have cruise. On the GT model, cruise is optional so depends on your luck.
I can meet you over the weekend if you need a hand. My cell number 416-587-4123.
BTW Ratko, your favourite dish at South Park:
"cha siu (bbq pork) gone chow (stir fry) yee fun (spaghetti)". But you should also try the "huck jieu (black pepper) au yuk (beef) gone chow yee fun". :grin:
