Shakey engine (vibrations)
1.9K views 29 replies 8 participants last post by  Matije pekovic
Hello everyone, I've been facing a vibration issue ever since I first got my Camry. It was originally my grandfather's which he never drove it. As of now, the car only has 80k miles. The car is a 1989 Toyota Camry DLX 2.0 I4.
Being in Arizona and the car sitting in the sun not being used for years, there were things I definitely had to fix (like the A/C). I've done a lot to the car but this vibration issue is the one thing I'm having trouble with.
Issue: Engine vibrates a ton. The steering wheel vibrates even more. The vibrations seem to be more stronger on the left side of the engine/passenger side. The passenger seat feels like a massage chair. Vibrations travel throughout the entire car. Vibrations get worse when in gear, when A/C is turned on, or when its very hot outside. Vibrations smoothen out with higher rpms.
I've researched a ton through discussions on this platform but I can't seem to find a solution that I haven't already tried.
Things I tried:
  • Replaced all motor mounts with a set on eBay - although original mounts weren't too bad
  • Timing belt kit service with water pump - bought on eBay
  • Removed throttle body and cleaned it completely
  • Replaced IAC with tested IAC - bought from junkyard
  • Replaced and calibrate TPS - bought from junkyard
  • Replaced AFM - bought from junkyard
  • Replaced spark plugs - New Denso copper ones
  • Replaced distributor + coil - bought from junkyard, also replaced wires and rotor (both new) but not cap as the one I bought had thicker leads and the rotor would hit them
  • Recalibrated timing using timing light while in service/testing mode (jumping the two leads on the service port)
  • Checked exhaust pipe, some pipe past the catalytic converter was rusted so I got it replaced as well as the muffler
For the idle rpm speed, I set it to around 750 rpm when in park/neutral with A/C off and around 900 rpm when in park/neutral with the A/C on. When going into gear, rpms drop by around 250 rpms for both cases. I set the rpms while in service/testing mode (jumping the two leads on the service port)
Everything I've tried hasn't helped with the vibrations. I dont get any check engine codes so I dont really have a clue on what else to try. Anyone got any ideas?
Thank you for your time reading this lengthy post everyone!
Aftermarket mounts are generally crap... so those probably didn't help anything.
Have you done a compression test on the engine? It might help to see if one or two cylinders is low on compression...
-Charlie
I'm thinking you have a dead cylinder on the engine. A way to check this is, while the engine is running, pull a spark plug wire off of the spark plug on #1 cylinder - if the engine runs worse, then that cylinder is working well. If the engine doesn't sound different at all when the spark plug wire is removed, that cylinder is not firing. Put the spark plug wire back on and move onto #2 cylinder, then #3 cylinder, and finally, #4 cylinder. If you find one cylinder that is not firing, check your cylinder compression pressures (as white90dx advised) - this will tell us a lot about the air side of the engine. If pressures are all about equal and good, check for spark. If spark is all good, check for fuel (injectors).
This is also a definite possibility with so much time sitting - things get sticky, drippy or clogged if they aren't used regularly.
-Charlie
There isn't much that the computer will report that would lead to engine roughness. No CEL for any sort of misfire. Only hint might be a lean or rich code.
-Charlie
Yes, I would suspect fuel next. Ignition issues will not present how you are describing things.
I you really want to get this solved, the next step might be getting the injectors cleaned (like, removing them and sending them off to a service like RC Fuel Injection or similar).
The mounts might still be an issue, but I run near-solid polyurethane mounts (for the F/R torque mounts) and even then I wouldn't describe the vibrations like you do...
-Charlie
#20 ·
I'm deciding to just replace both components and I've already got a Denso Modulator replacement but I'm having trouble finding an EGR valve. The part number for my current one is 25620-74150 but I can't find anything online to buy one. I've only found ones for the manual transmission and they have the left port blocked off which I need for a wire or connector that runs into mine (not sure what it is).
There's a valve that looks exactly like the one I'm looking for but it has a different part number: 25620-74240. Would it be a good idea to order this valve and see if it fits or should I try a valve from a junkyard nearby?
#21 ·
Per the parts diagram below, 25620-74150 is an EGR valve for a California Spec 1989 Camry 3S-FE. So I'm thinking that wire/connector you reference involves an exhaust gas temperature sensor, which is used on California Spec vehicles to verify there is EGR flow when the system is activated, and the temperature sensor senses the heat of the exhaust gas to provide this confirmation.
P/N 25620-74240 is an EGR valve used on 1995-1996 Camry's with the 5S-FE 2.2L engine and automatic transmission. It is also downward compatible with 1992-1994 Camry's. It does not appear to be compatible with a 1989 Camry though. Yet, in the bottom parts diagram showing 26520-74240, many of the other parts of the system share the same part numbers. I looked up 25620-74240 and I do not see any form of electrical wiring connectors or connections on it. That would lead me to believe it would be similar to a Federal emissions EGR valve for a 1989 Camry 3S-FE, but not your California Spec EGR valve. Perhaps you should show a close-up clear photo of your EGR valve with that connector so we can understand it better.
#24 ·
I think you may be right. Below is a parts diagram for the 1994 model utilizing 25620-74240, and it shows the EGR Gas Temperature Sensor 89412-33040. Now going back to the 1989 Camry 5S-FE w/ automatic transmission and California Spec, the diagram at the bottom also shows an EGR Gas Temperature Sensor, although this sensor part number is 89412-12010. So will your EGR Gas Temperature Sensor fit into 25620-74240? I don't know. But I'm thinking 1994 & up models didn't differentiate the EGR Valve by Federal & California, because both emissions types started used what was a California Spec EGR valve in 1994 going forward. I think it is worth a try, as long as your purchased EGR valve can be returned if your EGR Gas Temperature Sensor will not screw into the EGR valve.
#25 ·
I'm hoping that the different numbers for the temperature sensor is just because they changed the connector. I will pickup an EGR valve from Autozone so I have that possibility of returning it. Thank you for your help!
#29 ·
Update, it turns out 2 of my engine mounts were completely shot which included the front left engine mount. I decided just replace them all with actual quality ones although it was difficult to find them and had to order the front left mount like three times from different brands because they didn't fit. After replacing the mounts as well as the shocks, the vibrations disappeared.
Moral of the story: Buy quality motor mounts!
