It would appear that I have sticky lifters in my car. It makes a loud noise while warming up in the morning and quiets down a little bit when driving. Change oil every 3,000-4,000 miles and use Valvoline 5w-30. Any ideas of what to do?
Ok, I've been driving a long time but I've never heard of a "control valve filter"When I get time I am going to change out the oil control valve filter and see if it helps.
1ZZ-FE (DOHC) does have solid (not hydraulic) shimless bucket-type lifters. They're available in 35 different marked thicknesses of 0.02 mm increments from 5.06 to 5.74 mm. Some original lifters are in 0.01 mm increments.
I adjusted all 16 valves at or close to minimum spec at 100000 miles with 7 new lifters, and by switching the other ones around. I had a couple exhaust valve clearances at near maximum spec which could be heard ticking. The others were closer to middle of range, and all the clearances had increased since my 65000 miles check.
There's always a bit of piston slap noise before it's warmed up, especially in sub-freezing temps. It still runs perfectly and takes about 1/3 quart per 5000 mile oil change (Pennzoil Platinum synthetic 5W-30), now at 134000 miles.
