I did it: Camry Gen 4 to 4.5 conversion project that I've been planning/working on for a few months. The idea was to convert my 99 Camry to 00-01 Camry front end, with headlights converted to projectors (much easier to convert than gen4 lights). So, here's the result.
From this (after my car has had a misunderstanding with another car):
To this :thumbsup::
Some in-progress light-output comparison shots. You figure out which is which :lol:
My neighbor's car in front. This is the other side of the above pic.
I'll be break this down into four sections:
Parts
Installation & body work
Electrics
and everything else
I. Parts required.
a. Bumper:
Bumper cover. Two ways you can go down this road:
- Cut your existing Gen4 bumper cover. This will look ugly and I'm not even sure how it can work, though apparently some have done it.
- Get a Gen a Gen4.5 bumper cover, which will require some more Gen4.5 parts. This will look just like a Gen4.5 Camry front in the end.
I went with a gen4.5 cover. With it, you will need:
- 00-01 bumper cover. I got a used and beat-to-hell OEM one for $50 shipped. Had to sand, prep, prime, and paint it. You can get an aftermarket one for that price, but they suck, sag over time, and crack on first impact (OEM ones bend/deform, but don’t crack as easily)
- 00-01 bumper energy absorber. Mine was used OEM one from eBay - $40.
- 00-01 grill, new aftermarket $25
- The middle support for the grill that goes from hood latch support, as 97-99 one won't fit. I looted mine from a junkyard.
- Small plastic supports that go on either side under the corner lights, called "Bumper cover support". I believe P/N’s are: 52115-AA010 and 52116-AA010. I already had ‘em. Stealership will ask $5/ea.
You do NOT need a new hood, or bumper reinforcements (either small ones and the big one) - they're same.
b. Lights:
- Pair of 00-01 headlights (2x $25 for "regular replacement", $105-120 for a pair of clear Depo's)
- Pair of 00-01 corners (2x $10-25).
- Under-headlight supports, called “Reinf beam stay”, I believe. Parts# 52142-AA020 and 52141-AA020. Hint: they’re $2.13/ea on rockauto.com
- An assortment of electrical shenanigans for wiring modifications
I purchased a pair of clear Depo's already retrofitted with projectors. You can either put yours on as is, or retro them yourself (plenty of guides on that).
To this :thumbsup::
Parts
Electrics
and everything else
I. Parts required.
a. Bumper:
b. Lights:
