I didn't want to double post, so I combined a couple things into one post, hope that is ok.
About a month ago I noticed on my passenger side, the tie rod boot or steering rack boot (not sure of nomenclature here) was wet with fluid on the bottom of it. I wiped it down with brake cleaner, inspected it, but could not find any holes or cracks that may cause leakage. Wanted to inspect it again yesterday and saw that it was wet/greasy again. Now, as you can see in the picture below, there's a power steering hose/line next to it that is also greasy/wet. I'm not sure if its the hose leaking and spraying fluid on the boot or are they both leaking? I don't know what the probability of the boot leaking is, hence wanted to ask here. The steering rack is only a couple years old (installed around January 2020), its a reman that I bought from Jorgen Auto, they have pretty high quality remans of steering racks.
Can that little hose be replaced or it is the same case as with the upper part of the line where it meets the steering fluid reservoir where you have to buy the entire section?
What about the boot replacement? I imagine wouldn't be easy.
here's another shot from the other side (on the inside):
As for the sway bar bushing, I noticed a crack on it and was curious whether that's serious or not. I checked the driver's side and it also has a small separation which looks like it was manufactured that way to me, but the passenger side is much greater. Seems like it would be quite a pain in the neck to replace that bushing if I had to do it.
here's the driver's side for comparison:
Thanks for any advice!
