Tire Pressure Light continuously on - 08 Matrix - Is there a tire pressure sensor?
Tags
tpms light
8.9K views 12 replies 9 participants last post by  clem3
Hi - I've googled, and searched this forum, but can't find an answer to the problem I am experiencing.
I've owned my 08 Matrix XR since new. A couple of months ago, the odometer stopped working at 299,999 km (I'm in Canada) and won't advance to 300,000. Googled the situation and found that this is a known bug. Considered the various options and decided to accept the dealer's offer of replacing the instrumentation panel (speedometer, odometer, tach etc) at a discounted rate.
Dealer swapped out the old instrumentation for a new one. Immediately noticed that the Tire Pressure light came on. It flashed for about 30 seconds and then went solidly on. In 11 years of owning the vehicle the light had never come on (I had to look in the manual what the light meant.....I'm not a car guy....).
The same set of winter rims and tires has been on the car for three winters. I swap them over ever November and April with the summer rims and tires. The winter tires have rubber valve stems.
I called the service desk at the dealer (same night) and they said bring it back in and we will have a look. So I went back and a couple of service techs started looking at the problem. I googled some stuff on my phone while we are all looking at the car, and we couldn't find out why the light would come on. They checked the tire pressure on all 4 tires and there was no issue. We didn't check the spare, but it is one of those tiny tires, not a regular sized one.
I found a video that said you should use the TPMS re-set switch. We couldn't find such a switch.
So, my questions are:
* does my car have a TPMS re-set switch, or do I have a model that doesn't come with one?
* what's causing the light to come on (as noted above, I had never seen that light come on in 11 years)?
* how can I turn it off? (I've checked and the tires all have the correct pressure)
I can always go Red Green style, and use a piece to duct tape to cover the light, but I'd prefer a solution that is a bit more sophisticated.
Thanks
#3 · (Edited)
Rubber valve stems (in the winter tires) are a clue. Are you sure your trim level has TPMS sensors? Is it possible the new gauges came from a different model/year and the light is on because sensor signals can't be found? The low pressure light 'should' have come on every time you started the car (pre gauge swap) so you'd have noticed it.
Your owner's manual should tell you where the reset button is located (usually on the dash below the steering wheel or in the glove box). If you never had TPMS sensors just remove the light bulb.
If you know you have sensors in your summer wheels there's a pretty good chance after 11 years the batteries are dead. Try re-registering them using Techstream (or have the dealer/tire shop do it). If they don't show up in the program they're dead and need replacement. Again, just remove the light bulb.
Cheers!
I think this is the heart of the issue. I found a 2008 Matrix manual online that showed where the TPMS reset switch should be, if I had one (see attached image). But I don't have the re-set switch. The four slots on the dash to the left of the steering wheel are:
Glass (to open the back hatch glass)
A coin holder
Security light
Blank
I guess that means my car is not equipped with the tire pressure sensors, because if it was so equipped then the car would have the re-set button.
Your observation that the new gauges came from a different model/year is the most logical explanation. Thanks for your thoughts.
Thanks to all who replied on this thread, but I think I am going to use the Red Green technique of using duct tape to cover up the light. I'm not a car guy, so the thought of trying to remove the bulb or do something via the fuse panel seems way beyond my abilities. I'll cover up the light, and do what I've done every couple of months over 11 years of ownership of the car: check the tire pressure with a manual tire pressure gauge.
My '08 Tacoma had a sensor in the spare. I think they did that from '07-'09.
A clue, but no longer definitive. I had my sensors replaced when I put on a new set of tires, the replacements have rubber stems.
Check the spare?
Pull the bulb, or fuse, if it is a dedicated fuse?
Must harder to squelch the light than that. Some models can be disabled by applying a ground to one of the pins on the TPMS module, some require a TTL +5v. Pull the fuse or unplug the TPMS box and the ECU will hold the light. The dash light is an LED.
Easier to put a picture of one of the kids over the light.
Honestly... I never had any luck using the reset procedure on my Tacoma. I bought it used from a GM dealer and the light was on from day-1. I took it to America's Tire and they took care of it at no charge in 15 minutes. Apparently, one of the sensors had become unregistered.
But on an '08 Matrix, that's 10 years on the batteries in the sensors if they are OEM. I'd put $5 on one or more of them being dead.
Repeated flashing for a minute or so after startup followed by a steady light indicates a problem with the sensor(s) or TPMS module itself. Steady-On after startup indicates a low tire.
My 98 Sienna has a TPMS, does it also determine the pressure by comparing the wheel rotations versus transponders in the wheels (which I friggin hate). Heck my wife is a TPMS, I swear she can tell 2 PSI difference in tire pressure. I especially hate the systems that tell you there is TO MUCH pressure in your tires, since I like to lower my rolling resistance as much as practical by inflating my tires to sidewall max (all I'll admit).
