This is done at your own risk! Any ECU replacement MUST have the same part number that you are replacing.
Your Instrument Cluster Should Light Up Like This:
- Key ON
- Turn off all accessories (radio, blower motor, etc.)
- If you have a old or weak battery, make sure to add a trickle charger to make sure the battery does not die
- Obtain a jumper cable (paper clip, wire, two T-pins soldered to a wire, etc.)
- Jump the connector holes that are highlighted
- Forth connector hole from the top left
- Forth connector hole from the bottom right
- Nearly all dash lights should light up
- Wait 31 minutes
- Key OFF
- Remove jumper cable
- Make sure vehicle starts
- This may take two tries
