Worn key or ignition cylinder?
7.6K views 10 replies 6 participants last post by  shadako
Hi ToyotaNation members ---
About a year or so ago, I noticed the key sometimes wouldn't turn smoothly in the ignition on my 2001 Camry. When I bought the car, it came with one factory key and one aftermarket duplicate, but neither key had given me issues up until last year. The key always turns eventually, and the car hasn't left me stranded, but it seems to be getting worse. Another thing to note is that the key locks for the trunk and doors have always worked, but they were never smooth either (even before the ignition cylinder started giving me problems).
Seems like the problem is either worn out keys or a worn ignition cylinder. Is there a way to tell which is the problem? The fact that both keys seem to be giving me the same problems suggests that it's the cylinder itself, but the fact that the door/trunk locks were never smooth suggest maybe it's the keys themselves that are worn?
Usually it’s the keys that are worn. Look closely at the cut edge of the keys. They’re ok if the pointy features are worn a bit, but after years of use they’re typically worn badly. A dealer can cut you a new key given the VIN for about $10-20. Does your ‘01 have chipped keys? That adds some complexity, as you’ll have to program the ECU to recognize it. I believe there are DIYs in the sticky covering that.
Reactions: 97trophy
Luckily, I don't have chipped keys. I was hoping it would be the keys, since that would be much cheaper than replacing the entire cylinder. I'll give a call to my local dealer tomorrow and see how much it costs to get a new key cut. I hope that will fix it, but I'm suspicious given that both keys started acting up at the same time.
Thanks for the advice --- you've been very helpful to myself and many others on the forum :)
Reactions: fred9x
It's been said that it's not a matter of if but rather a matter of when the key ignition cylinder goes bad. Not sure but when I was still working at the shop I had to drop off the key cylinder for either a T100, Tacoma, or Pickup at the locksmith for them to repair because the key would not work or was stuck.
Couple things: When you go see your dealer (a code-cut key is a good choice, BTW), bring title or registration, and driver's licence, and make sure they all match.
Next, as to removing wafers: if you are really THAT worried that a miscreant would steal a 20 year old Camry, take a chill pill and calm down.
#11 ·
For anyone else, silicone or PFTE spray can help as a preventative for the cylinder jamming or to get the key out. Could spray a small amount in the cylinder and see if it helps. Also useful for steering squeaks and all other locks. You could also try tapping the key with a small hammer and turning. If you get it to turn to ACC, then you can remove your ignition cylinder without drilling. They can be rebuilt at a locksmith, if you want to keep your keys etc. Probably more useful for people that have chip keys (eg. the ones with black plastic) to avoid the chance of the car not recognizing the new keys.
