oops, confusion of terms:
OP, and earnhardtnov13 who revived this old thread, are talking about the hard steel lines which corrode over time, especially in northern, salty winters. They run from the master cylinder to the ABS unit to the proportioning valve on the firewall, then to each of the 4 corners.
balashark is talking about replacing the flexible rubber lines at each wheel from rubber to braided stainless, which have more resistance to bulging during hard braking and can provide a more responsive braking feeling. They only cost a little bit more than the factory ones.
In answer to earnhardtnov13's question: the cost to replace any of the hard steel lines will depend on how much time will be required to get access to the failed lines to install the new ones. Ideally, it will be quick, as they are fully exposed underneath the car. But it could get spendy if the access to the front ends is too hard to get to on the firewall where they are attached to the proportioning valve. Only your mechanic can say for sure. Also, the lines running from the front to the rear are packaged inside of a plastic housing, along with the fuel lines, not sure how hard it will be to separate out just the bad/rusted ones from it, or if the whole thing would need to be replaced as a unit.
Norm
