Hi Everyone, I been losing sleep and stressing over this Certified Used Camry that I bought back in 2/20/2013. Ever since I drove it off the lot I been complaining I'm seeing 11-12 mpg off the first 18.5 gallon full tank the dealership put in the car. They dismiss it as ethanol in the gas is giving me low gas mileage. So I been filling the car up with Shell REG 87, Shell REG89, EXXON 89 PLUS, EXXON 93 SUPER, SUNOCO 87 REG, GULF 87 REG.
Anyhow I was getting like 16 mpg on the I-95 going 55-60 mph on 20 mile trips and on 50 mile trip 14-16mpg going 55-55 mph on the first full tank. Now I noticed that at the time of fuel up I would get 22-23 mpg then it would drop down to 19 mpg before I reached my home destination. Then 2nd day it would drop down to 16 mpg then 3rd day to 13-15 mpg. Well I went to a mechanic I trust and he performed a Fuel Injection Flush on the car thick white smoke came out on 26,666 odometer reading used car. It gave me that day 21 mpg on I-95 20 mile trip then 20 mpg in the city till I got home. Then next day dropped to 17-19 mpg then to 16.6 mpg on the 3rd day and finally I'm back to 14.4 MPG-15 mpg after 30 miles put on the car. Now I do drive city miles and I keep it 1500-2000 rpm only at average speed of 30-35 mph to a peak of 40-45 mph on Roosevelt Blvd. in Philadelphia, PA.
So the mechanic looked underneath found no leaks or damage to the car rotated my tires with his hands no resistance or excessive heat going on there had 2 new tires put on and rear rotors done and air filter and oil changed along with cabin filter done at 25,584 miles. The fuel filter is bleach white clean the valves are clean the oxygen sensor are Denso factory along with the spark plugs (iridium 100k mile plugs). I drive the car like an old man because I got 20.5 mpg on my 18 year old car from not abusing it and with the front being heavier with a V6 engine and acceleration twice as much Horsepower I drive even more careful because I'm not use to the floating or acceleration this car gives. I bought an Ultragauge and take off at 100F and see an average of 185-195F on engine temp. To give you an idea I got 5.557 gallons on 4/13/2013 it had total of 6 slashes on the gas tank I'm down to 4 slashes and the Ultragauge is reading I lost 2 gallons in 3 days doing 30 miles on trip computer. So I did about 10 miles a day and lost 1/3 my gas already with EXXON 89PLUS. It was the same for other times I tracked it. Here is my fuelly.com Link- http://www.fuelly.com/driver/rabbit75/camry and www.fueleconomy.gov - https://www.fueleconomy.gov/mpg/MPG.do?action=editDiary&garageID=620074 which BTW they removed me after I dropped the 26 MPG AVG of the car to 20.7 MPG recently due to my 14 mpg average (not too happy about that makes me wonder if I can rely on this site).
Well I been keeping it around 5-8 gallon fill ups ever since the full tank due to my driving habits is 120-140 miles per 2 weeks. I take the same route everyday and same highway route using different gas mostly top tier 1 places. My average highway is 16-17 mpg my city 13-15 mpg lately. Went to the dealership with Toyota.com customer care ticket on this and diagnostics came back negative and they didn't perform any fuel flush services because of it. Yet my dashboard shows 14 MPG that day and my pictures in my phone showing tank gallons and receipts of how much and where I purchased the gas wasn't good enough proof to them because of the variables involved. It seems they won't take the care for more than 3 mile test run from the miles I took photos of leaving and entering there. So doesn't matter I have photo proof with latitude and longitude coordinates and time/date stamped on the photos. They explained that 12-16 mpg is acceptable gas mileage after talking to the head parts/service guy for 30 minutes on how could a Camry get the gas mileage of a dodge ram truck.
No check engine light or CEL coming back with codes and Ultragauge is not seeing pending or trouble codes either. So what could cause bad gas mileage that won't show up on the CEL? Tire pressure isn't a issue too has sensor for that and has been reset. Also reset my ECU taking off the negative battery terminal as recommended for driving habits to be learned again.
Would you accept this bad gas mileage on a Toyota Camry and think nothing is wrong here? I hope somewhere out there someone has a solution for me. I love this design as much as the 1995 and do not want to just give up on this. So please if you have a solution to this give me as much input as you can.
Here are some of the photos I took on the last 2 Fuel Ups on Fuelly.com
http://www.flickr.com/photos/sprint75/8659101995/in/photostream/lightbox/
