AC Compressor stuck engaged
39K views 17 replies 7 participants last post by  Donald E George
I think the ac compressor on my wife's 2008 Camry (2.4L) is stuck engaged. I've pulled the wire and it still didn't come loose. That being said, I've also read about a Mercedes that doesn't have an ac clutch, but rather the compressor vanes are varied to increase/decrease the compressor pressure. It's a shot in the dark, but perhaps it's the same with the Camry? It's been this way all summer (that I know of). The A/C seems to cycle on and off properly within the cabin. If it weren't for possible increased fuel consumption, extra drag on the motor, and possible premature component failure I wouldn't even be concerned with it. Can someone help clear this up for me and give me some ideas on what to do with this?
Shoot a quick video of the operation while someone switches the A/C on and off.
I doubt it's stuck on. If it did it would overcool the A/C and freeze the lines. Also you wouldn't have a noticeable on and off cycle.
Reactions: psycho_freke
A video would help. I have a 2009 Camry I4 I could instantly verify your operation against.
With A/C button on and the temperature control moved to Heat the A/C compressor still cycles to remove moisture from the air.
As an example in Defrost mode the A/C compressor is always on and the air always on fresh regardless of the button selection, temperature selection, or if you depress the recirculate button. This is to ensure moisture doesn't build up on the windshield from the vents.
#9 · (Edited)
@0:00 climate controls set to heat (vent and floor) with AC button "Off"
@0:16 Went into the car to turn AC button "On" (engine did sound like it had more of a load on it after pressing the button)
@0:26 Back outside the car under the hood to show compressor with AC button "On".
@0:48 Went back into the car to turn the AC button "Off"
@0:57 Back out to the front to show compressor with AC button "Off" again
Completely normal verified by my car.
Also I just remembered that when these cars came out there was literature about the Variable Geometry Compressor which required a special ND-12 compressor oil.
#11 ·
This?
Variable displacement vane compressor
US 4966531 A
ABSTRACT
A variable displacement vane compressor for an air conditioning system used in an automobile has a cylinder assembly having a bore which receives a rotor to form at least one crescent or compressing chamber between the rotor and the bore. The crescent chamber receives a refrigerant which is returned from the air conditioning system. The rotor has vanes which are extendably fitted therein so that the free end of the vanes are in contact with the circumferential inner surface of the bore during the rotation of the rotor, whereby when the vane passes through the crescent chamber, the refrigerant received therein can be compressed. The amount of the refrigerant introduced into the crescent chamber is adjustable in response to a change of a cooling load at the air conditioning system.
Also, according to this article Toyota has been using these in their Camry's since the late 80s and on Celicas in the 90s models... Wow! I guess you learn something new every day!
#13 · (Edited)
This is what I'm used to seeing. Notice how the center of the compressor stops spinning as the clutch releases? If the video was closer to the compressor you would also be able to see a gap between the compressor pulley and the clutch plate as the magnets release (you may still be able to if you look closely... I can see it). The gap opening and closing is pretty obvious in person.
