Edit, 9/9/14 - Test fit Evo Viii Brembos, Post #12
Hi guys, I've made a decision to implement some type of BBK solution on my new 2014.5 Camry SE. This post is just some FYI for anyone researching a front BBK on their 7th gen Camry.
I've been looking at ls430 calipers, acura rl and various other 4pot setups with good looking calipers. The goal is to have a great looking caliper and lighter/larger rotor.
When I searched this forum there were many posts stating "What about the IS350 caliper ......" Just to confirm NON FITMENT I tried my is350 caliper and stock rotor. The is350 caliper will NOT bolt on without adaptors. The rotor however will fit with slight modification to the dust shield. This is especially interesting because a 2-piece rotor for is350 weights only 11.5 lbs!!!
This also means that a Caliper for/from an IS250, IS350, IS-F and GS350 will not directly bolt onto the Camry.
IS350 Rotor left, 2014.5 Camry SE right-
Holding is350 caliper to 2014 Camry knuckle; you can see its not even close-
Junky is350 rotor on 2014.5 Camry SE-
Hope this helps someone when they search " IS350 Caliper " :grin:
