#1
Hello all, I’m having an issue with my Toyota Corolla 97 that I can’t figure out how to fix. At this point I’m needing help to figure out if this problem is solvable or not. (97, 4-door, no cruise control)
Here’s what’s happened:
I had my brake light fuse go bad and my gear got stuck in park. I was able to continue to use my car by using the shift control override. I replaced the fuse and was fine for a few months. Then it happened again, so I had a shop look at it. They did a bunch of testing on some of the wiring and ended up replacing all my brake light bulbs and the problem seemed resolved but they also told me that they weren’t able to locate the problem fully so it may come back. One week later, the issue came back. A friend found a wire with a crack on its sheath by the brake lights which he covered with electrical tape. I really thought that fixed it because my car drove just fine for 2 months or so. Then the issue returned. We suspected that it might be the stop light switch and replaced that one—but the problem remained, after just a quick ride to the store the fuse blew again. Next suspect was the shift control interlock solenoid part. I took apart the console and unplugged the shift control solenoid and the fuse still blew right away again. We unplugged another cable that we couldn’t figure out where it leads to right next to the shift control solenoid plug... Turned on the car and the fuse didn’t blow. Ha! We plugged it back in and still, fuse is going strong. That means that we still don’t know what the issue is and I’m at the end of my wisdom. Does anyone here had a similar problem, and is there a solution for it? My car doesn’t have any other issues and I don’t wanna have to give it up because of this wiring problem.. But I also can’t spend much more money on trying to get it fixed.. It’s been so frustrating as this problem solves itself at seemingly random times, to then return.
Any help is much appreciated!!! Thanks
