I thought for sure we had this info in 3rd Gen, Then I figured it would be in the manual, but NOOOOooo!
I hope this thread will be helpful. There is always more than one way to do something, so don't take it as some rule. This is how I approached the work. If you learn something from the info here, great! If not, feel free to add your say.
So since I have the brand new rotors sitting here, I better log it!
the OEM Rotors brand new are:
28mm thickness and Weight is 21lbs (the entire disc thikness), and 7mm thickness of each surface disc. (The rotor is not solid, so it is 2 discs sandwiched together with air vents between the 2 sides. *You only need the first measure I refer to/28mm).
The rear pads are 10mm thick.
The front pads I forgot to measure before I put them on.
*But I didn't need to change the rotors in the front or rear as they were still at about 28mm. Also they barely had any indent on the surface.
But, at 55K miles my front pads were well worn!
I had about 2mm of pad left on a couple while other 2 had 1mm of life!
Good timing!
I looked over the brake calipers and pins and gave them a bit of a dusting, and just replaced the pads.
I will check the rears tomorrow and see what they need.
Some added helpful info/via @MikeInNH and @Is973800 :
Lug nuts 76 ft lbs
Front bracket bolts are 77 ft lbs, (76ft.lb. 2nd Gen)
Front caliper slide pin bolts are 25 ft lbs.
Front flex hose to caliper is 22 ft lbs with new union bolt and gasket.
Rear bracket bolts are 70 ft lbs (2nd Gen 57ft.lb.
Rear caliper slide pin bolts are 20 ft lbs.
Rear flex hose to caliper is 16 ft lbs with new union bolt and gasket.
Specs listed for 2014-2016
Greasymechtech also points out when having this done, or doing it yourself to not take shortcuts....
"you don't want any shortcuts taken. Rotors need turning or replacing, pin seals needs replacing(simply hardware kit covers all), pins need a light coat of appropriate brake grease, pads need new shims, all rust/corrosion everywhere needs to be cleaned off, and a good thorough brake fluid bleed is a must. Obviously, you hope that the tech will use a torque wrench everywhere and is brake job competent. Most aren't. Calipers can be reused if not too old and seals aren't torn or leaking. "
Good timing!
Lug nuts 76 ft lbs
